- 7 Nov 2004
- Southampton/Oxford
has anyone had bad service from the ISP, 'Be', if so what was it, as im considering to moving to them from tiscali *pukes*
Dandle said:The service was taken over by O2 last year and will be rebranded at some point.
tim_enchanter said:All sounds good except
that would worry me
bikes said:I think it's been quoted on Thinkbroadband that it's going to be kept as a seperate entity.
Liquid_Entity said:I get this with Be There
ADSL Link Downstream Upstream
Connection 5441 kbps 1139 kbps
Line Attenuation 50.0 db 28.7 db
Noise Margin 7.1 db 6.1 db
Which is pretty poor but I am 1.7 miles from the local exchange, but it's far better, stable and quicker than when i was on Plus.Net's up to 8mb service - they only ever connected at 2300kbps down and 512kbps up.
For £3 more I am at least getting double/triple the speed I was once getting.
Heh, be have improved a great deal since O2 took them over, a lot of investment has gone in that they didn't have before. O2 have owned them for about a year now so probably most of the be users here are post O2 takeover customers.tim_enchanter said:All sounds good except
that would worry me
fothsn said:5441 is excellent for that line, 50.db is a very high SNR number (I’m surprised you’ve even got ADSL2) and I'm very surprised you’ve got such speeds, either your phone wiring is very poor or your line takes the sync route to the exchange if you are correct in stating 1.7M is as the crow fly’s to the exchange, I would try the Be* router in the master test socket and see what speeds you get
you may find a big improvement.
Be* are excellent I couldn’t recommend them enough if there available in your area they should be the first ISP to be considered, the only downside is the support & call centre staff.
Liquid_Entity said:Theres no plug socket near the master socket so am in the process of fitting one near to the master bt socket. Once thats on I will give it a whirl in that. I have taken away the original BeBox and replaced it with a Netgear DG834GT. I prefer the interface on it and I had one floating around.
Either way it's a vast improvement on Plus.Net who said I would never get more than 2mb out of the line lolz
squiffy said:Can you take a screenshot of settings used? I want to use a Billion 7300A, probably better router than the 780WL but can't get it to detect be there isp
