Beast build
Ah good plan, i have always given away my old gear too, i tried selling a CPU once, and the guy who bought it said it was dead on arrival, put me off trying to sell anything again.
Constantly upgrading is a good way to keep ya family and friends kitting out with PCs :) Make it an early birthday present for him.
Ye he can't wait to get it. i do have one more question tho will i have to reformat or will my ssd with windows on it work straight away in my new build?
It will work, it may need the ethernet driver updating.changing.
Personally with such a radical change of parts I do a fresh one.
I wish I had this kind of money to waste, oh wait a min ... neither do you lol:D
thought gpus are now king over cpus for gaming, making x99 a waste of money
Hey I built my pc but I had to put the CPU wire into the system fan slot because the other fans connected to the case would only work in the CPU fan slot is this a problem?
If it's the corsair aio then pump goes into sys fan and fans into cpu fan.
The cpu fans into sys fan header means it'll run at full speed all the time and really not how to do it..
There shouldn't be case fans in the cpu header.
What case fans are they? Are they 3 or 4 pin? 3 pin fans can go into 4 pin motherboard headers no problem
It's weird all the fans are connected to a switchboard on the back of the case which sends 1 wire out for all the case fans to work which only works in the cpu fan header it did also say in the case manual I should connect it to the CPU fan slot
Any fan control options for the sys fan headers to adjust within the BIOS?
That switchboard getting power from PSU?
I ordered this in the end what do you guys think.
adding gtx titan ssd hdd once it gets to me
You call that a beast??? :confused: :confused:
THIS is a beast!
:D
/Mick Dundee
