Beat Saber OCUK SCOREBOARD
20 Oct 2002
Oxfordshire / Bucks
Lets get a competition going
Default settings
no mods
practice or competition
*May ask for screenshot to prove your score
£100 Bills
Normal
melmac 168,511
shiwarrior 161,857
Hard
melmac 225,453
shiwarrior 221,304
Expert
Epoch 364,739
Unseul 353,653
SoundsGood 331,605
melmac 245,852
Beat Saber
Normal
shiwarrior 92,769
Hard
melmac 178,187
shiwarrior 168,907
Expert
Epoch 221,406
Unseul 220,553
melmac 201,391
Country Rounds
Normal
shiwarrior 171,731
Hard
melmac 237,367
Expert
Unseul 447,172
Angel Voices
Normal
Expert
Unseul 896,269
Legend
Normal
Hard
shiwarrior 169,409
Escape
Normal
Hard
shiwarrior 234,789
melmac 234,324
Expert
Unseul 336,919
melmac 223,830
Be There For You
Hard
melmac 275,988
Turn Me On
Expert
melmac 220,872
Rum N Bass
Normal
shiwarrior 237,878
Lnkin Park : In The End
Normal
shiwarrior 243,545
Hard
shiwarrior 340,113
Fitbeat
Expert+
Epoch 278,333
People can see it through the friends tab. So I think as long as you've got a friend here, you can just post the score? Is there a way to check scores outside of the headset?
You're specifying that it has to be using a particular headset? Seems a bit limiting. Does it make so much difference to your scoring capability?
Also, I haven't the faintest idea how to take a screenshot in VR! :D
Think he's just posting which headset he was using.
I think we will trust you.
I just got a million in all the levels, on expert plus too.
:p:D
:p:D
Dunno about a million, but you absolutely nailed $100 bills with that high score on hard! Perfect cuts? (Though I've read there's a bug? Probably fixed by now).
I've decided that I'm not going to do Hard any more, makes it really difficult to step up to expert after playing some songs on hard. Not that I can do many on expert, but without the constant rhythm it gets really tough.
Ah right, I've misunderstood that then. :o
I have actually been playing the included tracks the last few days, belatedly trying to make up for the lack of exercise caused by lockdown. I'll try to have a look at my highscores later today.
I have poor mobility in my left wrist. Which means I have to do full arm swings, I can't just flick my wrist to cut the blocks. So I don't know about perfect cuts, but I seem to be getting 100+ in most of them. It doesn't work in fast songs though. For example, I can't catch you in "be there for you" I just can't swing my arms fast enough and I miss a few cuts every time. In hard mode if you miss a cut it's possible to recover but in expert and expert plus, if you miss a cut during one of those frantic sections!! Well, it's all over.
I will keep trying though!! It's so addictive.
Yeah, wrist movement is essential in some of the expert moments, when you get a string of 3+ rapid blocks where you only know the direction because it's the opposite of what you just did :D.
You know the ones that get me are the ones with one block on top of the other with the arrows pointing opposite directions. For some reason it takes all my concentration to do these.
The other thing that my poor dumb brain can't compute is the songs with the different colour sabers and the purple and gold blocks. I keep going for the purple blocks with my left hand.
I turned that off straight away. I only have the blue and red on everything. Can't be doing with that!
Fit Beat ?
it confused me the first time i did that song
anyway, lets get back on topic, otherwise it be the beat saber thread :D
anyone going to upload some scores ?
any headset :)
Song: $100 bills
Headset: Quest 2
Dificulty: Expert
Settings: Default
Score : 331,605
Tried to do Expert+ but couldnt survive for more than about 20 seconds!
Right. Only putting up expert scores for now.
Song: $100 bills
Headset: Quest 2
Difficulty: Expert
Settings: Default
Score: 301891
Song: Beat Saber
Headset: Quest 2
Difficulty: Expert
Settings: Default
Score: 220553
Song: Country Rounds
Headset: Quest 2
Difficulty: Expert
Settings: Default
Score: 447172
Song: Angel Voices
Headset: Quest 2
Difficulty: Expert
Settings: Default
Score: 896269
I can see I'm going to have to try $100 bills a few more times.
