jcb33 said:Which is better this monitor or the Acer AL1916WS 19"?
daven1986 said:yeah photos would be nice, im still gonna buy 2 though!!
daven
Im realy not sure the Belinea or the Acer, and even when I do make my mind up, should I buy 1 and run it with my Viewsonic VA2012W 20" or buy 2 and sell my Viewsonickbc said:Get some high quality shots up of this monitor when you do daven!! Take it you're ordering tomorrow?
jcb33 said:Im realy not sure the Belinea or the Acer, and even when I do make my mind up, should I buy 1 and run it with my Viewsonic VA2012W 20" or buy 2 and sell my Viewsonic?
Pictures will be ace though please![]()
daven1986 said:i will get them up ASAP, promise. im ordering tomorrow and will get them on wednesday
daven
True, but i am not sure i can fit them on my deskkbc said:Are you sure about that? A Viewsonic 2012W has a better resolution of 1680x1050...![]()
Could get another Viewsonic instead? That'll make dual 20"... as they're going pretty cheap as well.![]()
Yes! That'll help greatly! Tell us how you get on with them too in regards to gaming and watching movies.
Plus can i realy justify another £250, and i need to send this one in, as it has a nice pale line on atm that runs horizontaly from the left for about 3cmjcb33 said:True, but i am not sure i can fit them on my deskPlus can i realy justify another £250, and i need to send this one in, as it has a nice pale line on atm that runs horizontaly from the left for about 3cm
But the size of a 20" monitor isn't that much larger than a 19". So the amount of deskspace occupied between the dual 20"/dual 19" will be minimal. Guess it depends on how much you value the cut in resolution i.e. from 1680x1050 -> 1440x900.Hurry Hurry, want to get in before they go up in pricedaven1986 said:argh no stock today, they should be with me on thursday so will post pictures then
Am realy thinking hard now to, Do I:daven1986 said:argh no stock today, they should be with me on thursday so will post pictures then
jcb33 said:Hurry Hurry, want to get in before they go up in priceAm realy thinking hard now to, Do I:
1) Buy 1 19" TFT, and have it run dual with my 20"
2) Buy 2 19" and sell the 20"
3) Buy 2 19" and use the 20" as a tv in the living room, well a media center pc
4) Buy another 20" and run it dual...
but whats better 1 20" or 2 19" for the same price
If you really don't want to take that option then do option 1 to be honest. Saves unecessary spending.... but I've not checked the maths.
kbc said:I would do option 4 jcb33.If you really don't want to take that option then do option 1 to be honest. Saves unecessary spending.... but I've not checked the maths.
