Benching problem
12 Jan 2013
Gdansk, Poland
Hi guys
I bought my 2nd 780 and wanted to do some benching with both in SLI.
The problem is, every benchmark I run shows two gpu's, but results are same as on old ones with a single gpu or worse.
I am using Precision X.
So far, 3d mark extreme, Unigine valley and heaven 4.0 and Sniper elite v2.0 shows no improvement over single gpu.
Any idea on what could be wrong?
Did you enable sli in nvcp??
Fairly sure it needs to be manually enabled every time you either add a card or update the driver :)
