benchmark testing .....help
23 Mar 2010
hi
so i bought this new PC about.....a month ago....just want to know what software i should use to test benchmarks
i heard i could test ...RAM ....HDD ....computer performance etc...
anyone consider any for me?
my PC Spec if it helps:
Intel Core i7 930 2.80GHz (Bloomfield) (Socket LGA1366)
Corsair XMS3 6GB (3x2GB) DDR3 12800C9 (1600MHz) Tri-Channel (CMX6GX3M3A1600C9)
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
Asus ATI Radeon HD 5850 1024MB GDDR5 PCI-Express Graphics Card
Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX)
Corsair HX 650W ATX Modular SLI Compliant Power Supply (CMPSU-650HXUK)
Coolermaster Storm Scout Gaming Case - Black
BenQ G2420HDBL 24" Widescreen LED Monitor
3dmark - gpu performance can use for light stability testing (w7)
furmark - gpu stability, normally used to test for errors when overclocking gpu (w7)
cinebench - gpu/cpu performance can be used for stability test w7
HD tach - hard drive performance (need to run windows xp compatibility with in w7)
prime95 - cpu and full system stability - good to find max temp of your cpu/chipsets (w7)
super pi - cpu/system benchmark can use for light stability testing (w7)
mem test - as title this tests your memory for errors. best way is to run from usb pen
