Hi all,
I'm just about to fit some cat6 face plates but wanted some input regardss how much bending of the cat6 I can get away with.
As you can see from the photos my cat6 cable is coming into the drylining box from the back but the faceplate connector is vertical. Will this bend in tje cat6 cable be ok of should I swap the faceplate for one that has the rj45 jack connection horizontal.
Thanks.
Thanks.
