BERSERK MSI AND X79 SYSTEM DEALS
11 Dec 2005
Cheshire
For a limited time only, we are offetring a mental deal on the "Ultima Prism" system and the MSI X79A-GD65 motherboard which has a FREE Thermaltake Frio CPU cooler and Tomb Raider; Guardian Of Light Game. Save £400 on the "Ultima Prism" system which features the latest Intel Core i7 3930K CPU overclocked to 4.20GHz.
"Ultima Prism" Intel Core i7 3930K 3.20GHz @ 4.20GHz DDR3 Hex Core System @ £999.98 inc VAT
Introducing a new game changer, the "Ultima Prism", harnessing the all powerful Intel Core i7 3930K Hex Core CPU. Unlocking the true potential of the CPU with a mental 4.20GHz overclock. The Intel X79 chipset allows for quad channel memory an industry first allowing for unlimited bandwidth and ultra high capacities to be utilised. Choose your favourite DX11 compatible graphics card for the ultimate gaming experience. Consider pairing the "Ultima Prism" with an optional SSD upgrade, to provide split second boot times and lightning fast transfer speeds.
Why You Should Buy This System
- A guaranteed 4.20GHz performance for the price of 3.20GHz
- Choose from a selection of graphics cards to meet your performance needs
- Precision built and cabled by Overclockers UK expert technicians
- 8 Hours stressed tested and quality controlled
- USB3, SATA 6GB/s, Intel Ethernet for next gen computing
- Quad Channel DDR3 memory for unlimited bandwidth
- Hex core processing for seamless multitasking
System Specification
- Case: Coolermaster HAF 912 Case
- Power Supply: OCZ ZX 650 PSU
- CPU: Intel Core i7 3930K 3.20GHz Sandybridge - E overclocked to 4.20GHz
- Motherboard: MSI X79A-GD65 Intel X79 (Socket 2011) DDR3 Motherboard
- Cooler: Thermaltake Frio CPU Cooler
- RAM: 16GB (4x4GB) DDR3 Quad Channel Kit
- Hard Drive: 500GB HDD
- Graphics Card: DX11 GFX Options
- Sound: Onboard 7.1 Audio
- Optical Drive: OcUK 22x DVD±RW SATA ReWriter - Black
Service Package
- Full 12 Month collect and return warranty
- Each specification is assembled from handpicked components for compatibility and stability
- Telephone, web note and forum technical support
Is this System for You?
Weild the power of Intel X79 and next generation Hex core i7 power with the "Ultima Prism".
Note - If you would like to make a small change to the specification call our sales team on 0871 200 5052 and they will be happy to help.
*Please allow between 24 and 48 hours for your system to be built and configured. This may take longer during busier periods.
Was £1399.99 Inc. VAT
Only £999.98 inc VAT.
ORDER NOW
MSI X79A-GD65 (8D) Intel X79 (Socket LGA2011) DDR3 Motherboard with FREE Thermaltake Frio Advanced Cooler & Tomb Raider Game @ £239.99 inc VAT
Comes with Free Thermaltake Frio Advanced CPU Cooler & FREE Tomb Raider; Guardian Of Light Game
- Supports 2nd Gen Core i7 Processors in a LGA2011 Socket
- Supports DDR3-2400 (OC) Memory
- Supports USB3.0 & SATA 6GB/s
Military Class II
- DrMOS II: Next Gen DrMOS, Double Thermal Protection
- Hi-C Caps: Tantalum Core, 8x Longer Lifetime Than Traditional Solid Caps
- SFC: 30% Higher Current Capacity
- Solid CAP: 10+ Years Ultra-Long Lifetime
- MIL-STD-810G Certification: Tested By Independent Laboratory to US MIlitary Standards
PCI-Express Gen3
- 2x Bandwidth up to 32GB/s
- Increased Efficiency and Compatibility
- Extreme Performance For Current and Next Gen PCI-Express Cards
Click BIOS II
- Provides a consistent user interface both in the UEFI BIOS and in Windows
- Graphical User Interface with Touchscreen Support
- Simply Click or Touch and Move To Change Settings
- Full System Control, Including Overclocking, Security and Information
Specifications
- Supports 2nd Gen Intel® Core i7™ Processors in an LGA 2011 Socket
- Intel X79 Express Chipset
- 8 DIMMs support for DDR3-2400(OC) / 2133(OC) / 1866(OC) / 1600 / 1333 / 1066MHz up to 128GB max
- 3 PCI-E 3.0 x16 Slots
- 2 PCI-E 2.0 x16 Slots
- Supports AMD® CrossFireX™ & NVIDIA® SLI™ Technology
- 8-Channel(7.1) HD Audio subsystem with THX TruStudio Pro
- 10/100/1000 Mb/s LAN subsystem
- 2 x SATA 6Gb/s ports from X79 with RAID support
- 4 x SATA 3Gb/s ports from X79 with RAID support
- 2 x SATA 6Gb/s ports from ASMEDIA ASM1061
- 2 x IEEE 1394 ports (1 Rear / 1 Front)
- 4 x USB 3.0 ports (2 Rear / 2 Front)
- 12 x USB 2.0 ports (8 Rear / 4 Front)
- 1 x PCI-E x1 slot
Was £279.99 Inc. VAT
Only £239.99 inc VAT.
ORDER NOW
just out of interest, is this a Frio/MSI product partnership or is this just an ocuk thing?
the reason i ask is because if it was an actual MSI/Frio thing they had going, you'd have thought they would have matched the colours a little better :p
Technically it is an MSI thing but they have done it exclusively for OcUK, agreed the fan could have been blue but at least you can change the fan :)
the prebuilt ultima prism is actually cheaper than buying the components separately :eek:
(i know ive posted this in the OcUK builds thread, but i thought it would be worth sharing in the deals section too)
I'm sorry but why on Earth would i buy it if it was more expensive? I thought the idea behind the pre-build systems was they were cheaper than buying all the components separately. Am I missing something?
^^^ The reason i asked was because the way it he wrote it. I sounded like it was a bonus that the system was cheaper. The ONLY reason i would consider buying this if it was indeed cheaper than picking my own parts. And 400 quid off is a heck of a deal imo
I'm sorry but you thought wrong, usually the systems are MORE expensive then buying the parts separately. yes you get the odd occassion such as when the pre-built system is on a offer such as here that it's cheaper then buying the parts.
the reason the prebuilt ones are normally more expensive is because someone at overclocker has to spend time building it, overclocking it and testing it. your paying for that service as well as the parts, and an entire system warranty for one year.
this is why i was shocked that it was cheaper than buying separately and building yourself
Yes you are.
The extra charge on top of the components, is to pay for the technicians time they spend, building, overclocking, configurating and quality controlling your system. It also pays ffor the 12 months of phone/webnote support and warranty.
These items above unfortunately are not free.
Would you expect a car to be expensive built or just in bits?
Allow me to disagree with you.
You build a system so you can sell more components at once thus making more profit. This "time spent building" is just a bad excuse in my eyes. When you go to the shop and buy a suit for example you do not expect to pay extra because someone matched it do you? When you buy a case of beer, you do not expect to pay more because it comes in a package. To use your car example: When you buy a car do you pay premium because someone spent time to build it and quality control it? Surely not. If you decide to buy all the parts a car has and build it yourself you would pay significantly more...
This is just my opinion.
It isn't a discount bundle, it is a pre-built system.
We do not sell them as discounted bundles or even wish to.
We offer the products and service (building etc) as one price.
This maybe your opinion but your opinion is wrong. Businesses do not do things for free unfortunately. If the case was otherwise, then it wouldn't be business.
I hope this helps.
Are you trying to say that when you buy a car, they haven't factored in the cost of manufacturing/putting together that car on top of what they paid for the parts? Cos I think you may have a strange idea of how a business costs its products if you do....
Missing the point any company like OCuk with prebuild systems will be more expesnive as they have to pay for the time and care taken, also the AFTER sales support.
But you do pay extra for a tailored suit or a hand built car, products made by experts to squeeze that little bit extra from the same components and provide maximum quality. Thats what OcUK do. Their cable tidying and overclocking alone make their systems worth that little extra premium, let alone the careful selection of components and after sales service.
I am seriously tempted by this, alas, I would not have the monies until the new year :(
I posted in the new forums and asked if there was a particular reason that £400 was being shaved off? The components don't look old hat to me... just wondering. Also, would the overclock be easy to raise or would the 16GB of RAM no allow it :)
