Best 120mm fan?
ill give it a go, i got a noisy comp at mo anyway, sli 7800gtxs, 2 120mm fans (quite loud) and some hdd bay fans too
just want a bit more air being thrown onto my XP-120 and my opty 165
i got my speakers normaly up loud (200watt rms logitec) or my headphones on, so dont notice the noise :) , i would go to watercooled, but never even attempted it before and water vs electric sounds bad :)
Its fine if you use distilled water, but the problems only occur if one of the water-cooled components fail, because if they do then your chip will cut out, but might not cut out in time to save the chip, as I painfully found out. Im going back to air myself after having my fingers burnt.
If you dont mind the noise aspect, maybe you should consider phase-change cooling? Im sure the serious hardcore O/C'ers could tell you more, but only if you can afford the hefty £500 price tag. On the upside, you make that money back with the level of O/C'ing you can perform :D
Can you hear a hoover over your speakers if it is about 5 foot away?
If you can you won't like the delta, because it could drown out the hoover with ease :D
YEah i 2nd that, they are lound enough at 7v let alone 12v. Id get a louder Speaker setup mate, try 1000rms that sound dim the sound from the Delta. :D
hehe, well im runnin 1 **** 120mm fan on me XP-120 at mo , some jeantech thing from pc world, thats loud enuf, but i want more wind :P
[Death] said:
it cant be that bad surely :P
My friend has a delta, when he turned his computer on I thought "Wow, mine is quiet but I cant even hear yours" I then realised I had gone temporarily deaf*
*This may or may not be true
