i have an i7 4770k overclocked to 4.5ghz on 1.25 volts
after a run of OCCT the max temps are around 80c with a corsair h100i stock fans set at 1200rpm (any faster than that is to loud)
im not very happy with those temps, my case is a corsair 500r it has pretty good airflow but im abit of a silence freak and a little bit to much noise for my liking comes out of this case
im going to be swapping out to the NZXT h440 as soon as the black and red version is available on overclockers, done a little bit of research on the case and im thinking it might be a little bit restrictive airflow wise wich might push the temps up even higher on my CPU
can anyone reccomend a 240mm AIO that will outperform the h100i?
ill be buying a couple of coolermaster jetflow red LED 120mm fans to stick on it, ive heard they are brilliant for static pressure and pretty quiet if you use the 1200rpm limiter
they are also the only static pressure fans i have found with LED's
