Hi guys, Not long ago I was looking at a Custom loop but I don't think I'm going for that now.
Which is the best 280mm AIO Looking at the Swiftech H240X, Corsair H110i GTX, Raijintek Triton 280mm any others I should look at?
I would like the Swiftech but I'll need to change the tubing to transparent add another coolant etc.
Corsair H110i GTX which would be easiest option but I would need to change the fans to two Noctua's, Downside is black ugly tubing.
Raijintek Triton had the 240mm which I returned as I heard the 280mm was coming out, Mines ran fine however as I read the thread I know that they are plagued with problems leaking 5 months down the line etc, This is also the cheapest.
What your opinions? Which would you go for?
