Best AIO to go for I9-14900KS (sorry probably asked a lot?)
Well so far so good, way better temperatures than the previous one. 25-33 idle, lots better temps on games no longer hitting the 90-100 on cores at times so looks to be way better than the previous one :)
Question tho, choice of cables i used the Single 4-Pin connector rather than the individuals and connected it to the CPU_FAN pins on mobo, previously it was 1 to the cpu fan and 1 to the AIO_PUMP connector... Cant see the AIO speed from armoury crate now, this anything to worry about or this all good (if that made sense)
Don't worry it don't show up in armory for some reason, I just set the my cpu fan in bios to 100%,good to hear you like it :)
Yeah impressed can barely hear the PC at all so the fans on this are a lot quieter than the corsair h100i also.
Cheers for the advice all :)
Yeh it can be tricky to mount but don't let it put you off, best way is to leave the cpu in the socket to prevent damage, also a little tip put electrical tape on the support bracket on the back of the motherboard to keep it in place as it can move.
Cheers for this tip btw, i was going to do this and got some electrical tape, but with having the previous bracket for the Corsair in i left this screwed in while putting in the frame, glad i didnt have to take the whole mobo out of the case!
Mine was done in the case as I couldn't be bothered to take it out, lucky for me I got it when artic did the promotion as I only payed £80 for it, I wasn't looking to change aio but its white :)
That looks sweet!
I need to do some cable tidying when i get a chance lol its a bit messy current (just getting bits in to test) depends if i can be bothered though :D
Aye the cable tyding can be a pain as it can take hours to do, but you system looks nice and rgb as we all know rgb is life :)
That looks sweet!
looks good mate. The fan cables should be able to be tidied up together and sit next to the ram
Arctic iii has been so far so good most I've seen is about 70 on some cores now and again gaming so it's a lot better than my old aio. Cinibench was hitting 100c still but tweeked voltages a bit n seems max 97 on cinibench
I can live with that so yep cheers all for the advise again
thats great. Glad you happy with it mate
will do, only issue i think i may have is if the radiator+fans fit the top of the case as i think it may be a very tight fit and may block me getting the mobo cables in but will see
Will block your access to 2 x8 pin CPU power on the MOBO. My Arctic 280 mm is shorter so I can push it towards front of the case in order to access that area. However I don't need both CPU 8 pin as my Ryzen will go only 90W.
Managed to fit in fine but tight but no bother
In my picture it was a tight fit but they where ok, it was the cable combs that where the only problem.
