Best air cooler AM4?
2 Jan 2016
Yorkshire
Looking for one that will give me enough clearance for my RAM slots, all 4 of them are Corsair vengeance RGB pro and are to the right hand side of the CPU slot, on my current setup I have a Kraken AIO but because of the pipes I had to have the cooler off centred to be able to fit.
I don't overclock my CPU as I find the boost more than adequate.
Thermalright Assassin King 120 SE. Overclockers don't sell it but it can be purchased for £21.90 elsewhere. It may not be the best cooler but it'll be within a couple of degrees of a £100 Noctua on a stock 5600x, there's no point getting anything better if you're not overclocking.
I'm using it with a 5700G, running Cinebench R23 with the fan at 100% the max it reached was 68c. With the fan at a fixed 700RPM which is inaudible to me it reaches 77c.
Do you push/pull or just the one fan pulling?
One of the best coolers for the money (£33) with 100% ram clearance is the broken 3 and virtually silent.
It's 165mm tall so check it fits ypur case.
Cool, 190mm according to Be quiet so I should be good
micky I hope the reason it is virtually silent isn't because its broken! :p
How is this one of the best for the money? It's more expensive than the Thermalright AK120 and performance looks to be well below average.
Its silent which does sacrifice a couple of degrees but is a 3rd of the price of the dark rock pro4 . Compared to the assain king 120 the assasin is a good cooler for the money but its not the peerless assassin which is £45 monster but cover ram slots..
The best cooler for not covering ram slots is the u12a, way too pricey but its a beast. Have it on my 13900k, handles it like a champ. Now whether you willing to spend that much is a different story.
That the Noctua? I was considering the u12s chromax.
I can't find any noise normalized reviews for the Alpenfohn Brocken 3 but it gets beaten by the Hyper 212 Black edition in this review, which is a below average cooler itself. The Assassin King 120 is most likely the better cooler. The Peerless Assassin 120 SE is currently £35, but in this 87w 35dBA test the Assassin King 120 is only 0.9c behind the Peerless Assassin 120 and 1.9c behind the Noctua NH-D15.
This is the best single tower cooler, but OP is running a stock 5600x. It's debatable whether a 400% price increase is worth running at 71 degrees instead of 73 degrees. It would be interesting to know how good the TR AK120 SE is if you put 2 of those Noctua NF-A12x25 fans on it.
Well, the u12a can do this, with a 13900k
260w at 85c
330w at 95c
It can score higher, I was just trying to bench the cooler instead of the CPU
