Best Air cooler for £40?
8 Jun 2005
Hi all,
I'm looking to replace my Arctic Freezer Pro 7 because it's the only thing I can still hear in my rig and I want to overclock my CPU.
I notice there are LOADS of coolers for around the £40 mark so I'm after a decent recommendation.
My primary concern is silence. I already get good temps when OC'd on this cooler, but I don't want to hear it.
thanks,
G
I'd also recommend the Thermalright HR02 Macho.
Have it cooling my i5 3570k at 4.3GHZ never peak more than 65 degrees in gaming.
Great cooler for the money also VERY VERY quiet.
I have a Nanoxia Deep Silence 1 case.
/edit Maximum installation height of CPU coolers 185 mm
Wide case body allows 185 mm tall CPU coolers
Due to the generous width of the Deep Silence 1, it can accommodate CPU coolers up to 185mm tall meaning virtually any CPU cooler currently available will be compatible.
I have a spare Gentle Typhoon, could I put it in push pull on the Macho? Does it comes with additional mounting brackets for a 2nd fan?
Thanks,
G
Nanoxia Deep Silence 1 is a nice case. Would be interested in your thoughts about it.
It has 185mm CPU clearance so clearance is no problem.
HR-02 has only one set of fan clips but adding a second fan is only 1-2c better cooling.
With that kind of clearance you might want to consider the True Spirit 140 £34.99
I didn't mention it before because it is 170mm tall so not as universal as HR-02. TS140 does have 2 pair of fan clips.
http://www.overclockers.co.uk/showproduct.php?prodid=HS-108-TR&groupid=701&catid=2330&subcat=2352
Thanks mate :)
I absolutely love this case to be honest :)
The cable management is so good that it doesn't even look like much is plugged in! This is how it looked when I had my two 570's in there:
I now just have a single 780, the case is completely silent apart from my CPU cooler now. I currently have 3x GT's in there and I'm going to take the one I have on the side of the case off and put the sound deadening back over the 140mm hole in the side of the case.
Thanks for the pic. Very clean looking.
Here are reviews of HR-02 and TS 140.
http://www.overclockers.com/thermalright-hr-02-macho-review
http://www.overclockers.com/thermalright-true-spirit-140-heatsink-review/
http://www.hardwaremax.net/reviews/kuehler/430-test-thermalright-true-spirit-140.html?showall=1
Last one is German with sound clips at speed and idle. With PWM fan you can set your own speeds dependent on heat so should be able to keep it silent.
I'm using same family of fans (TY-140's and TY-143's) The TY-147 is a Black/White TY-140. ;)
TY-143 is red/orange and 2500rpm/130cfm. I have 143's on cooler and 140's for case fans. All are PWM controlled by mobo CPU fan socket and idle 650-700rpm and full load 900-1100rpm. Can't hear system at idle and just barely at full load. i7 980 never goes above 50c. I ran HR-02 on mine and found it only a couple degrees warmer and still quiet.
Cool so it looks like the TS140 is a better one than the Macho depite being smaller in size? (apart from height)
Installed now :) Temps running prime temperature test went from 98c max to 77c max :)
The drop in volume is VERY good. Exactly what I was hoping for :)
Looks like this now:
Considering taking the 120mm GT off the side panel of my case and putting it on the back of the new heatsink but I don't know if there is much point?
Cheers,
G
