best air cooler for an opty 146 pls. £20 budget.
Permabanned
11 Mar 2004
im currently using a vantec mach 1 which you can see here
http://www.overclockers.com/articles1231/
it cost £17 and keeps my venice 3000 @2.5Ghz around 45oC under load. im looking to clock my opty 146 to 2.85Ghz and am thinking im probably going to need a better cooler. what do you think and what do you suggest ?
also what are the acceptable load temps for an opty 146 ?
17 Aug 2003
Woburn Sand Dunes
the freezer 64 pro is about the best you can get @ ~£17.
temps <~57c ideally. less if your clocking it far. My 148 @3ghz loads @ 48c/3ghz using a scythe ninja. £31 so out of your budget, but its so good and so quiet:)
Permabanned
OP
11 Mar 2004
well im not adverse to paying more if it will DEFINATLY get me good results, ive just had a lot of bad luck with coolers in the past, always end up sending ££ on a supposedly good cooler just to find its either bloody noisy or crap at cooling. i had a coolermaster extreme once upon a time, the thing came with an 80mm delta screamer. 80 decibles!!! :eek:
17 Aug 2003
Woburn Sand Dunes
well for the price they are the only two you really need to concider. the freezer is dirt cheap and an excellent performer. the only drawback is that, at least compared to the scythe with its 120mm fan, it isn't exactly silent. If you can put up weith that, then its perfect for you:) i love the scythe because it really is that quiet, even with the fan @ 12v.
17 Aug 2003
Woburn Sand Dunes
Permabanned
OP
11 Mar 2004
any thoughts on the Zalman CNPS7700-CU 12cm Silent CPU Heatsink ? its still a little over my budget but more affordable to me than the scyth.
5 Jul 2005
Brighton
Freezer 64 pro TBH ;)
Running my venice at 2.5 ghz @ 1.55v and I get 38-41c load and is currently idling at 31c with the fan running at 80% speed (near enough silent) and best of all I only payed £11 :D
Permabanned
OP
11 Mar 2004
your running an A3000+ venice at 2.5Ghz and you need 1.55volts ?! :confused: mines doing 2.45Ghz with stock voltage... you might want to drop it a little, could get you even better temps.
5 Jul 2005
Brighton
No a 3200+ venice, and no I cant drop it any more. It has been running like this for ages and isnt stable any lower, I got a crap clocker.
Permabanned
OP
11 Mar 2004
ouch, :( a 3200 too, thats a lot of juice it wants for a small clock, that must be one hell of a cooler then lol :)
Permabanned
OP
11 Mar 2004
TaKeN said:
SCYTHE NINJA .
BEST CPU COOLER IVE EVER USED :D
and yes, ive used the Arctic Freezer,
firstly it looks real complicated, second, its out of my price range anyway :( 3rd im not entirely sure it would fit in my case lol. but all reviews read good, i will say that much.
5 Jul 2005
Brighton
Aye :( got it cheap though. £90 brand new retail 6 months ago so I cant complain. They were £120 everywhere else
Permabanned
OP
11 Mar 2004
indeed :) i got my A3000+ sent from america back in august 05, cost £97 inc shipping :D although i only had to pay £20 for the postage as i did some work for my friends brother in georgia.
30 Jul 2005
Midlands
shocking. then again then resonant engineering sub i had next to the pc did have a triple stacked magnet that put out a very large magnetic field. must be difference in subs.
