Best airflow case
Shove in a couple of Delta crossflows and airflow should be sufficient ;-)
Got a Stacker 810, can fit upto three 12cm intakes, has a side vent (can only fit a 8cm here though) top 8cm fan, two 12 exhausts. I'm just using two front, two rear
Mozart TX case ?
I have one and seems pretty good
But tbh if i had the chance to turn back time i probs would not get it as it so dam big lol
Also there seems to be a lot of wasted space if you get what i mean.
antec 900 with all of the 120mm fans replaced with deltas will give you the best airflow and it may cause deafness
