best 'allocation unit size'
28 Nov 2003
Manchester, UK
I'm formatting a 500GB hard drive which I will be using as my primary C drive with windows vista 64 on it, so my question is which allocation unit size should I select, for the best performance?
Capacity: 465GB
File System: NTFS
Allocation unit size:
default
512 b
1024 b
2048 b
4096 b
8192 b
16 kb
32 kb
64 kb
So, does it make any difference at all? I think the default is 4096 as that is what was already selected. Thanks :)
