psu is corsair and i have just updated all motherboard stuff as ive only just installed
Okay, but did that include flashing the BIOS to latest version? Just to avoid confusion as you weren't specific.
As Lude said - it might run an FX-8 (it is supported with latest BIOS) but it's really not a good motherboard* for it at all. I would stick with the FX-6100 until you can get a better board for a better processor.
* http://www.overclockers.co.uk/showproduct.php?prodid=MB-415-GI
You're looking for a whole rig then?
I'm not sure I'd want to put an FX-8 in that board. It is a very cheap board with cheap power components, I used to have one with a 955BE.
What is the rest of the system spec?
e; ah I see most of it above. What make/model is the PSU?![]()
what components will you be needing?
