Best AMD upgrade from 3600.
Depends what you use the PC for, IE if it's just gaming then a 5600X will do the job and can be had for £200 in the uk at the minute.
Only gaming really
For gaming, a 5600X. Prices have been dropping on them quite a lot recently. Also note that AMD are about to release 5600 (non-X), 5700 and a few more in the next month or two, so hold fire for now and see what comes.
Mind you, all depends on the games you play, the resolution you play at and the graphics card you have. Might find that any upgrade is simply not worthwhile (i.e. older GPU and high-res. gaming, for example.) Check out the bazillion reviews of the 3600 versus other CPUs out there on YouTube.
I hear they are releasing a non X version of the 5600 soon so that should be your upgrade although you could also pick up a used 5600X if you spot one.
3600 vs 5600X thrumbelumph
Depends on your screen resolution. If you're playing at 4k you will not notice much difference. At 1080p there will be quite a difference
I am on 1440p with a 2070 super and just chucked in a 5600X because by the time I have sold my 3600 it will be £70-80.
Anyway.
Not a great deal of lift from 3600 in Cyberpunk or RDR2 (I had read that) but lows are much improved. However 15% in GTA (DX11) and Firestrike DX11.
As for everything else, I have not really noticed a huge difference other than I have 3-year warranty and it was a relatively cheap uplift. So worth doing.
sounds like a waste of money Stringsad, you notice litte difference other than 15% in a 10 year old game and a benchmark you can't play
What the best upgrade I can get with the board. And is it work it.
If your happy with your current performance then its not worth it. If you want a performance increase that you will usually not tell with the naked eye then a 5600x or 5700, when it is out, are reasonable upgrades especially if you sell your 3600 to reduce the cost. As above it depends on the resolution you game at
