Best as in fastest and largest hdd for £60-75
24 Oct 2005
North East
Need a new hdd can get ata or sata 1 on this motherboard asus a8v deluxe rev 2. Lookin to get the most space i can and also percendicular tech and gotta be near silent and fast.
Was thinking of segate 7200.10 320gb but that was a choice i was considering a few months ago so duno if theres anything better out there now. Any ideas for me?
I want to transfer my 30gb partitions to the new drive and make it c drive and have windows on. (how do you transfer a c drive 30gb with 2 partitions to a new drive and keep the drives C:)?
Fastest is a toss-up between the Seagate 7200.10 and the Western Digital AAKS series, flip a coin or go for the cheaper of the two as it won't make a lot of difference. The only other thing to consider is that some of the 7200.10s use a different motor to others which is meant to be a bit noisier. :)
Only difference between the two mentioned above is that Seagate offer a 5 year warranty compared to Western Digital's 3 year warranty. The Seagate is a little more expensive, but only by £2 at the size you want.
Robbie G said:
WD YSRE is faster than the AAKS series.
What's that based on?
The YS series is the previous generation to the AAKS. Every benchmark I've seen puts the AAKS significantly ahead.
I have 3 Seagates brought in the last few months and not had a noisy one yet.
I have a 7200.10 and a 7200.9 and cant really notice any speed difference between the 2.
picked up the 500Gb 7200.9 for £75 delivered, bargain.
^ Even the noisier ones aren't all that noisy, from what I've heard. I personally am not worried about getting a Barracuda even from all that has been said.
I will settle the ys vs aaks arguement on monday i have a new 320gb aaks
which im on now my rmaed ys re returns monday.But i have a nasty feeling theyve sent me my old unit back and have merely plugged it in to see if it works.
Robbie G said:
Why did you RMA the YS?
Was dead on arrival wouldn't format past 60% and fails in western digitals diagnostics tool
as well as all others i have tried it has bad sectors.
