LeoWyatt said:
Well the cheapest i've found is 1600 which isn't too bad.
Though would you guys suggest getting a 5 speed or 6 speed tubro version?
would you consider this?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4623450772
or is this too good to be true? infact it is, he doesn't have the red key.
Get an expert to see that first.
Clutch slip - as I said above, this will cost a minimum of £330 to fix.
Oil Leak - well, he could be right about it being the rocker cover. A new gasket is only £15 and its a job you can do yourself if you follow
my guide. However to be honest, if it was that, then why hasn't he already done it?
Bonnet release handle broken
Never heard of that before. Could be a bit of a pain. You could probably get a new one easy enough. Plenty of coupe's being broken for spares.
Airbag warning light on. Again, this is something I'd want an expert to take a look at.
It looks ok, but its one of those where you really can't tell from a picture of his description. If you can get it for £1500, then you can set aside another £1500 to get it sorted.
If you can afford it, get a 6 speed as they are newer. The best model is a 20vt Limited Edition, but obviously thats gonna cost more. I'd be a bit wary of an LE for £3000. For that price I'd be look at a P - S reg 20v turbo with about 70-80k on the clock, and certainly not in bright yellow or red. To me that screams 'I want a lambo or ferrari, but I'm poor'.
If you want a real gem, try to find a Vinci Grey one.
