- 20 Oct 2005
Hi guys,
I've just got the EVGA 3090 and it's producing a ton of heat compared to my 1080ti. This was to be expected but I wanted to check that I have my case airflow correctly setup. My previous 1080ti was a founders edition with a fan blower design so my case setup did fine, but with this 3090 my case has been turned into a radiator.
The card is idling around 58 - 60c and +80c at load.
My setup
EVGA GeForce RTX 3090 24GB FTW3 ULTRA GAMING
Intel Core I7-7700K 4.20 GHz Socket 1151 8MB (overclocked to 4.6ghz)
Asus rog maximus ix code lga 1151 atx intel motherboard
Corsair Dominator Platinum Series 32GB (2 x 16GB) DDR4 DRAM 3000MHz C15
Corsair Hydro Series H100i v2 Extreme Performance Liquid CPU Cooler
Corsair AXi 860W Fully Modular 80+ Platinum Power Supply
3x Corsair Sp120 Rgb Fan - With Controller
Jonsbo RM4 Zone Window ATX Aluminium Case
https://www.quietpc.com/jonsbo-rm4
I'm aware my current setup is old and not suited for the 3090 but ill soon be upgrading to a 5950. However, in 4k gaming the 3090 has performed well, with the exception of FS2020!
Thanks in advance!
My setup
Thanks in advance!
