- 9 May 2005
Well I have just had a hair raising experience this morning, I bought a budget case and power supply off of the bay and installed my hardware in it this morning, after numerous cuts to my hands due to pointed metal and sharp plastic I turned it on.
Blue smoke out the back of the psu and a bang, naturally I thought the worse and got my gear out of there quick time, luckily everythings alright, the psu must have been real poor as it was only running 1optical/1ide and a celeron with onboard vid/sound.
So anyway, I need a case for around the £50 mark, Im going be upgrading quite a bit in the next week and will have a Enermax 500W to go with it, what do you suggest?
I was looking at the Soprano, is it any good?
Whats the build qualiy like on the Thermaltake.
