best case for wc
26 Aug 2010
glasgow
so what is the best case for watercooling. a cpu and 2 670's
i was looking at the elysium then a nzxt phantom and also a switch but they all have thair ups and downs, is there a perfect one or is it all a matter of opinion?
corsair 800d.
Te be honest there is loads of case's that are good for watercooling but it all depends on what style you like.
It's more a matter of what you are prepared to do to the case to make things like rads and pipes fit, I have the fractal XL, cut some of it about and I have a 480mm rad and 240mm rad in it and loads of space left for hdd's and such.
budget really depends on what it is, not ready to pay for something like the 800d. thats why i looked at the elysium, but thyen started looking at the 810 switch.
oc3d's review of the elysium was really good but then at the end his sum up kind of put me off.
ill look at some vids of the switch.
Silverstone TJ11 or Corsair 800D
For a bargain, look at these:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-OE&groupid=701&catid=7&subcat=2225
