Wurth dry chain lub.
There chain cleaner is pretty good to.
I have that too, only used it twice and the first time I thought it was rubbish but on the second use its quite good.
If you do high miles they are fantastic. I miss mine and will get another. You have to adjust the flow rate depending on the temperature, but they keep the chain in very good nick and don't fling if adjusted appropriately.I was the exact same.
One thing I cannot stand are scotoilers I have never had one but i think its just laziness plus i like to look at my chain and check it regularly.
