Best Cooling Solution?
best bang for buck has to be the Noctua NH-U12P SE1366
and there is not much between the top coolers 1 or 2 degrees here or there
so my money would be on Noctua NH-U12P SE1366
Water is great, but the maitinace is soo high, that and every time you adjust something you need to tweak the rest. And the price are unbelivble, even barbs set you back a massive amount. Unless you have money to waste I would get a good tower cooler or a kit like the H50
I'm gonna pass these coolers by now and go for the Corsair H50. Way smaller, cooler and cheaper than most and will fit all processors, even the new Lynnfields.
megahalems is a great cooler for oc, just took mine off only had it 3 weeks. moved over to water now, temps are about the same, but with less fans so a bit sound:)
