best cpu cooler for amd am3?
are you running the chip at stock or planning to overclock it?
if you are going to OC it, how much, what sort of voltage are you shoving through it?
whats the thermals of your case like? what case have you got, what intake and out fans are you using?
I do want to OC it. don't have the case yet, should be either a haf 922/932 or X depends on my finances..but they do have good cooling (don't they?)
sorry if I wasn't accurate enough in my description
+1 for the fenrir.
No other cooler has managed to have such a decent combo of price/performance/size/simplicity/cost.
You will top out around 4.0ghz way before heat becomes a problem. It is largley the architecture that limits things not heat. You do not need anything more on am3.
