We need like an AMD unlocking thread with a big table showing everything.![]()
I think the *unlock* aspect is quite fun, although I'm slightly wary it's an evil-genius marketing plan from AMD to sell more chips!We need like an AMD unlocking thread with a big table showing everything.![]()
The Athlon II's run extremely cool, no need for a fan on the heatsink if you keep a reasonable overclock and vCore! . . . I think the 6MB level 3 cache on the Deneb core does make them run a fair bit hotter.dare I say it I might go AMD for my studio PC build![]()
I can afford £120 on the CPU on its own.
Is the AMD Athlon II X3 425 really the best for the £120?
Wouldn't one of the below be better?
Intel Core i3 540 3.06GHz (Clarkdale) (Socket LGA1156) - Retail [BX80616I3540]
Intel Core 2 Quad Q8400 LGA775 'Yorkfield' 2.66GHz 4MB-cache (1333FSB) Processor
Intel Core 2 Duo E8400 LGA775 'Wolfdale' 3.00GHz (1333FSB)
AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3)
AMD Phenom II X3 Tri Core 720 Black Edition 2.80GHz (Socket AM3) only £100
Intel Core i5 750 2.66Ghz (Lynnfield) (Socket LGA1156) - OEM £145
Sorry I wasn't fully aware that was the case?I really seriously would NOT move from a E6600 @ 3gig to an AMD X3 setup... you WILL be dissapointed - thats not to say its a bad setup just won't be much of a move forward
Hehe good advice, I couldn't agree moreand I'm also going to say don't listen to big.wayne
What do you mean I am talking to much about my 1 month old system, sorry I can't help it, It's really good!hes completely hung up on these budget X3 systems at the moment
In your humble opinion or?the most cost effective upgrade path - even tho its a dead end - would be to see if a Q9400 or Q9550 works
What else can I talk about then? . . . I got nothing else to do apart from helping people with their trouble-shooting
Is it something we can discuss or is it carved-in-stone?![]()
Don't get me wrong - those X3 setups are mean little packages... but the OP sig says "GA-965P-DS3P Rev3.3. C2D [email protected]" which I assume is what hes upgrading from... and tbh for gaming they won't give a significant increase in performance or smoothness...
Spending £120 on a 955 then motherboard, etc. comes to quite a bit more than buying a Q9550 which will generally be better for gaming - and chances are it will work with his board tho I need to find comfirmation of that... and tbh theres no guarantee the AM3 platform he buys will be any more upgradable down the line than the LGA775 platform - its quite common with AMD boards that new generation of CPUs goes beyond the wattage teh board is designed for even tho the socket is compatible - amongst other changes.
Yes but there is no shame in that? . . unless we are having different meanings of the word "Pimp"you have yourself been pimping AMD for the past few weeks
Rroff, the problem I have hear is you have stormed into a thread where a pleasant discussion was talking place, broadcasted to the interweb to "ignore" me and declared that a 2 year old [45nm] chip is the one true option!Don't get me wrong - those X3 setups are mean little packages... but the OP sig says "GA-965P-DS3P Rev3.3. C2D [email protected]" which I assume is what hes upgrading from
Does the 785G perfrom better in windows 7 than the new H55 and i3?
