Fuzion v2 is one of the best, and for a few Quid extra you can get a nozzle accelerator and a quad core midchamber insert
Looking for best performing CPU block around for LGA775
Like the look of the EK supreme with clear top but apparently it is a pain to fit so i am leaning towards the D-Tek fuzion V2
Any comments?
Who says the EK is a pain to fit? They're all the same - 4 thumbscrews through the motherboard, get a backplate if you want to do it properly. The EK backplate is the only one I know of that comes with a neoprene insulating mat that means you can really clamp it down tight on the motherboard.
low presure/multi block single loop - XSPC Edge
everything else any of the top 5 will do (as said above) what ever you most like the look of
The edge has been discontinued unfortunately due to manufacturing issues.
CPU Blocks - 14/08/08
After a very short product life we are now moving on from the Edge CPU block design, due to production issues we could not manufacture the block in sufficient quantity. To replace the Edge were now working hard on our new block the Delta V3 which should be released before the end of August. We will post some details of the block as we get closer to release.
