Best Defrag Tool?
9 Oct 2006
Location Location!
I havn't defragged my PC since i got it ages ago - just ran the analyze tool on the built in one and it's almost solid red and I noticed the hdd seems to be hanging waiting for the hdd's (raid 0) a lot recently so i figured its time to fix it.
Been trying O&O defrag on trial but it fails to install the service and its driving my insane not working and the lack of support.
So question, what would you recommend to defrag a PC? Trial software will be fine just need to fix the hanging.
Diskkeeper is good imo, but also needs a service to work, and perhaps try running 20 loops of windows defrag?
I'l see if Diskkeepers service will install.
Edit: Nope... wtf.
Will take a look at PerfectDisk too :) Ty for suggestions.
Edit: PerfectDisk is working :)
Need one myself too! Ever since dropping in a X2 4200 Windows Defrag doesn't want ot work! Keeps coming up as "Not responding"!
Perfect disk or O&O
diskeeper isnt that bad but IMO Perfect disk is better
and O&O gives you more defrag strategies
and for people not wanting extra services what i do is have the set to manual/disabled then enabling them when i defrag
not like you need to do it often
Are any decent defrag apps free?
Still using Windows defrag, yes I know it's just a cut-down version of Diskeeper, but it is handy.
Yeah I use Auslogic Disk Defrag too. Seems to work fine for me in Vista, pretty basic but does the job fine it seems.
