Best DLP projector under £1000?
This thread has a load of good suggestions - top end slightly above budget but should give you an idea:
https://forums.overclockers.co.uk/threads/1500-projector-needed-for-6-nations.18766973
Personally I'm not sure of the need to go mad unless you are wanting 4K, professional installation and/or very large screen setup - there are many very decent offerings in the £500-800 range that you won't really be able to tell the difference from many more expensive offerings in the average home setup (assuming that is what you intend).
