best dos programme help
6 Jul 2006
co durham
ive lost my O/S and ive tried installing it again on the 3 partitions ive got on and it wont install keeps giving error,so is there a programme i can use to wipe all partitions of and format to ntfs,is there a programme that boots up from start as ive got no other way to format it cheers
Sounds a bit drastic, what is the error?
Are you sure your drive is OK? have you checked it for errors
how would i go about checking it for errors as i dont have a O/S on it now,and thanks for help,i will try it again and see what error it gives and let you no
http://www.ultimatebootcd.com/
Linux based boot CD. It contains a load of drive checkers to make sure you drive is ok, and you can use it to format your disks or partition them as NTFS.
http://gparted.sourceforge.net/screenshots.php
Alternatively you can use this to partition your drive, it's a bit nicer looking. Again, it's Linux based but will work fine for Windows filesystems.
All you need is a CD and a CD writer; put the burnt CD in your drive, select to boot from it, and off you go :).
