- 6 Dec 2006
- Barnsley
I have been using a Pacific DVD player that is coming to the end of its life. I am looking for a replacment under £40 inc delivery that will play DIVX, AVI and all the normal stuff.
I have seen one that also supports usb so can just plug in my 1gb mem stick and play films off that.
Anyone got any recomendations for this as this DVD player is used loads in the house.
This is what I have seen but never heard of the make???
Technical information sheet of XS-390 DVD Player
The XS-390 DVD player is the ideal equipment to watch your favourite DVD films while in the company of your friends and family.
The XS-390 is a complete living room unit compatible with MPEG4 format, and supports most rewritable CDs and DVDs.
The XS-390 also comes with a USB port at the front so that you can connect your mobile external devices such as an MP3 player.
As for connectivity, the XS-390 is equipped with S-Video, composite and component outputs as well as a 5.1 audio output.
The XS-390 DVD player will guarantee you hours of entertainment!
Contents Region Zone 2
Standard NTSC/PAL
DivX/MPEG4 compatible Yes
Compatible Media DVD, DVD+-R/RW, CDR-RW, CD-R, VCD, SVCD, Photo CD Supports
MPEG1/2/3/4, WMA, AC3, JPEG Formats
Removable recording supports No
Internal hard drive No
Internal hard drive capacity (in GB) -
Integrated Audio Decoder Dolby Digital AC-3
Video Out S-Video output
Video composite output
Video component output (Y, Pb, Pr)
Audio Out Coaxial digital audio output
Audio 5.1 output
Scart Adapter 1
Included Accessories Remote control
AV Cable
Manual Information will soon be available
Dimensions (mm) Information not provided
Weight (kg) Information not provided
Other USB port with outgoing MP3 recording
Screen saver
OSD multilingual menu
Different play modes: prgrammed play, search
Parental control
Standard NTSC/PAL
Audio 5.1 output
Scart Adapter 1
AV Cable
Screen saver
Parental control
