Best format to use for Synology backup drive?
Commissario
16 Oct 2002
In the radio shack
I'm about to hang a large USB 3 drive out of the back of my DS1019+ for weekly backups and was wondering what I should format it as. I only have Macs in the house so if it all goes bad, I'll probably need to access the data via a Mac.
Any suggestions please?
As a weekly backup of the Synology?
May be better to hang it off a Mac, and then copy the data across the network
Aye, yes, sorry. I didn't make that clear. This is to run a weekly backup of the contents of the Synology.
I want to try and fully automate this from the NAS itself. I think I can configure a backup in Hyper Backup and have it eject the drive when finished so my plan is to have a smart plug on the external backup power supply so it will switch on a certain time, the backup will start two minutes later and when it's finished, it'll eject the drive.
Then somehow (not 100% sure how yet), I want the drive to power off fully. I’m thinking I might be able to use IFTTT to notice when the drive has been ejected and send a switch off command to the smart plug.
I went with HFS+ which means I can read it natively on the Mac but although the Synology can read/write HFS+, it won't format it to that so I had to plug it into my iMac first. I've used USB Copy instead of Hyper Backup.
