BF3 for £50 eh i wish lol cant say where from (rules) but id go pre-owned on that budget, you will have to look around and compare on some benchmark sites, depending on what you can find.
I'd prefer new.
Is BF3 possible on a £50 card? ..or £60 tops.
and I dont want to OC (heat/noise)
If you want better, used would be best but not ideal. I'd save up.
I definitely want new, not used. I notice AMD have a new 28nm technology which is probably a lot more efficient than the 40nm technology. One review I read said it means 50W compared to 150W for the older boards. So it means buying new. So far I've found a 7750 at £80 but is there anything else within my budget? http://www.overclockers.co.uk/showproduct.php?prodid=GX-294-SP&groupid=701&catid=56&subcat=1699 And is it any good?
No. The 7750/7770 cards aren't very good for the money in comparison to the last generation of cards.
460 is still a good card. and you realise that things wont really advance until the next gen of consoles next year? it will be fine till then, not max settings all the time. but still
