Best Hot Hatch Tyres
18 Oct 2002
Leicester
Hi chaps,
I'm a bit out of the loop with the best tyres. The size is 225/40/18 for a Focus ST (remapped and so on).
I don't care about how fast they wear just how they perform really. I've liked Eagle F1's in the past but I guess things might have moved on a bit?
Cheers.
He wants Pilot Sport 4S.
Are these even available in 225/40R18?
I know there were a couple of 18" sizes available for PS4S but generally they're only in 19" fitments aren't they?
For an 18" tyre, you're looking at a toss up between F1A5, PS4 and PC6 i'd have said
Any reason the Continentals don't get a look in with these discussions? for a hot hatch they generally mesh well with "sporty" driving even if some aren't so happy with the comfort but who drives a hot hatch for comfort?
They made a big marketing fail I think.
Merging the Premium Contact and Sport Contact ranges was fine but they retained the Premium Contact name rather than the Sport Contact name.
The obvious downside being most enthusiasts associated the long standing Premium Contact name with good touring tyres but not as something competing for top honours in the performance tyre arena.
Historically I think the Sport Contact range had a reputation for wearing very quickly compared to Pilot Sports and Eagle F1s.
A lot of my experience is broad but not in depth when it comes to these things so stuff like tyre wear I don't have much experience of.
The Michelin 4S isn't available in 18s in the UK, so the alternatives are Michelin PS4, Goodyear Eagle Asymmetric 5, Conti PremiumContact 6 which are all fairly equal performance wise. Alternatively, Goodyear do the Eagle F1 Supersport in 18s, which is closely matched to the Michelin 4S
iirc Tyre Reviews said the sport contact should NOT be classed as "sport" because its more of a comfort tyre
The latest review from them comparing the PS4, F1A5 and PC6 on an Octavia VRs has the Conti as the most sporty feeling tyre of the lot and the PS4 as the softest feeling.
Pilot sport 4, I have them very good tyres, only criticism is very cold weather they don't perform, but, I guess that could be said about a lot of tyres and you should be driving slowly then anyway :)
I bought some Kumho ecsta ps71 for my Fiesta St and they were brilliant, after running it on pilot 3's I didn't notice any difference.
I'd hit the Ford owners forums and see what enthusiasts are putting on their cars. A tyre can perform much better on certain cars and not that great on others.
