Best LED Controller?
30 Dec 2004
London
Just wondering if anyone could shed some light on LED controllers. Trying to put together a COB Strip with a transformer and wireless controller but not sure which wireless controller is best. If I can get one that can be used with Apple HomeKit that would be great - but I am not sure which to get. I've done some research and seen things mentioned like Zigbee etc but I'm a bit confused.
Just want a controller that uses an app that is fairly well known that I can expand things with (not Philips Hue as they're too expensive).
For example, I'v seen a Milight Miboxer LED Controller - but can that connect to Apple Homekit? I've seen Zigbee mentioned then Matter? Feels very confusing and difficult.
I'd like to just get the right system wiht one interface so later on I can add more automation to it verus having one app for the LEDs, one app for thermostat etc etc
Any help would be appreciated.
Zigbee is just a communication protocol, in a similar way to WiFi or Bluetooth. If you don't already have a zigbee network then you won't be able to control a zigbee LED controller.
If you have a Hue bridge then that will provide a zigbee network, you can integrate 3rd party branded controllers with hue to allow it to control them. I've had good success with Gledopto controllers for many years.
I'd echo this. Had good experience with the gledopto controllers and hue. They also sell a version that includes RF so you can control it from both a physical controller and the Hue.
