Hello,
I got the micro server setup today and did take much more time to setup than I had hoped but mainly due to some unlucky circumstances.
To start with I've got a 30 day trial of MS Home Server as I did not want to commit more £££ if I could not get on with it. I've also held back from adding a new HD, wanted to play with it a bit first
Anyway, installing the OS was just as simple as any other windows installation but did take quite a while to complete with updates and everything but that’s to be expected. First thing I did was setup Utorrnet with web gui and forwarded the ports to make it work, so happy with that. Next thing was setting up network shares again very much like how I have already done with my W7 machines I basically don’t bother with the home group and open everything up to everyone in my network.
The biggest pain in the ass for me personally was setting up the remote web access. It all seemed very simple as the wizard took me through the steps but at the end when it came to log in through my .homeserver.com address I just got "page could not be displayed." So I went through it again and again, no joy. I started to hunt around the interwebs for answers. Turns out that the billion 7800 upnp does not communicate well with MS Home Server. Ok so manual port forward time, find out what port (443 it turns out) then we're in buinsess. Again no luck, it seems there has been many people unable to get the port forwarding on the billion to work with it. Spent hours hunting around and people seemed to be respond with port numbers they'd picked out of the air. I thought bugger it whack it in the DMZ, bang straight in. So still a port issue. I just could not get these ports everyone was suggesting to open up the routers been factory reset 5 times today and MS Servers gone in twice. But just as I thought it had beaten me and I would have to beg you guys for help I noticed one of the predetermined port forwarding profiles in the Billions list box was HTTPS TCP 443. I cleared out all the manual forwards I had at that point and selected just HTTPC 443. It worked!! I was very happy, but I don’t understand why it did not when I tried it manually, a bug? Something stupid I missed?
Any way happy I could log in at last I started to play with the streaming, some videos work some don’t guess it’s down to codec but all my mp3s come through great. I guess the next thing to do is whack in a 2TB drive and relocate the shared folders.
So in summery apart from the port forwarding issue (not the micro servers fault) it wasn't as problematic as I thought it could have been. I switched off the CTL ALT Del logging thing, could not be doing with that. I've got it all setup almost to a point where I can leave it alone to do its thing. The only complaint I have is the remote access does not allow you past the dashboard so you can’t mess about with the setting in the OS, I could always install logmein or something though.
