- 11 May 2006
Currently using the 285.62 WHQL drivers - should I be using anything else?
About the same kind of boost this would give you.
http://forums.bethsoft.com/topic/13...formance-increases-now-in-skse-plugin-format/
Constant locked 60fps no matter what I'm doing or where I am in the game.
Also allows you to install high res texture packs, which are kinda cool...
But before I installed that loader I was getting around 46fps minimum.
When installed the new beta drivers, 290.53, it wasn't going below 53fps.
Hope this helps.![]()
Sorry but thats not 100% true is it. There are still some parts of the game that put my fps below 60, but its because the game doesn't utilise gcards properly at all -.-
Well thats just from my experiance playing, I've never noticed my fraps monitor saying anything other than 60-62. Although I haven't really spent a lot of time playing skyrim with the loader yet, just visited some of the major cities to test the performance out.
The new 290.53 drivers are pretty awesome though, specially in bf3.
*edit* BTW Merry Christmas!![]()
