best overclocker out of these two?
It all depends what your max target is and which motherboard and memory you are using.
Say your max FSB speed was 500Mhz
The E8200 has a Multiplier of 8 so 8 x 500 = 4Ghz
The E8400 has a multiplier of 9 so 9 x 500 = 4.5Ghz
The E8500 has a multiplier of 9.5 so 9.5 x 500 = 4.75Ghz
ah i see, the m/b will be gigabyte either ds3l or ds3r, and the memory will be 2gb pc-8500 probably the geil black dragon ones. will the gigabyte boards go up to 500fsb?
The board will, but IME of the 4 wolfdales i've had none of them are stable on air or water above about 470fsb and will generally hit an FSB wall at around 500.:(
Apart from my new DFI motherboard that has so far let me get the FSB upto 530mhz and I reakon there is more there still.;)
right ive decided, e8400 it is then, any good board suggestions up to £80 ish would be really appreciated. i'll be using a tuniq tower as well
