Liquid ultra is best
If I delid it I wonder how much I'd see shaved off the heat?
Hi mate, literally posted this earlier with pics on mine:
https://forums.overclockers.co.uk/showthread.php?t=18747853
I did it on my 6700k because temps were getting progressively worse. Without a doubt under the IHS Liquid ultra (link in my thread) is the best performer, on the IHS to cooler use a good normal compound, I used Gelid Extreme and its pretty good stuff. Mine dropped 10c Idle, 15c ish load... Be careful to research your CPU and note how close the delicate stuff is to the glued adges (6700k is miles away).
Hope the thread helps...
Use some electrical tape to stick your pcb to the vice so it doesn't go flying!
Have you researched the vice only method?
Depends on your chip, sandy bridge a lot, has well a good chunk, Skylake not so much.
I honestly wouldnt put it in a vice... Why not just cut it.
I've just paid someone to do it and lap it at the same time.
Just Google delidding service.
How much did they charge?
I paid 15 for the delid then another tenner for the lapping.
Would have been 20 but I sent my own paste.
Are they covering it against damage for £15? Presume you also pay postage.
