Best phone for Remote Desktop
POB
POB
27 May 2003
Its a Small World
Hi
I need to occasionally use Windows Remote Desktop to fix server issues if they arise.
Is there a good phone for the job? Any experiences?
I'm thinking a highres windows mobile may be the best option.
27 Aug 2004
Geordieland
Presumably the higher the res the better, so im thinking TouchHD or possibly the HTC Hero if a program exists that will let you use it.
Caporegime
18 Oct 2002
All over the world...
Winmo phones are your best bet...they have a built in app that allows you to remotely control your desktop...whether its any good is another question entirely...ive never used it when i had my touch diamond.
26 Mar 2007
Nottinghamshire
Acer Tempo F900...
Essentially the same spec as the Touch HD but alot cheaper. Saw it yesterday sim-free yesterday for £189.99 from a very popular online retailer, obviously cant link to it here but a quick search will reveal where.
When you consider its spec execpt for it 3mp camera .(800x480, WM6.1, Wifi, HSDPA, Bluetooth etc) its an unbelievably good price.
Their is also a vid on you tube with the Acer alongside the Touch HD which shows how much faster the Acer is and it also has a larger capacity battery...
POB
POB
OP
27 May 2003
Its a Small World
Thanks guys the Acer sounds a good deal.
Will have top look into what O2 offer for a data connection on my contract.
