- 2 Apr 2009
- Location, Location!
Lenovo P2 easily the best at that price point.
G4 Plus on Amazon Outlet for around £125 a couple days ago.
is it the z pro or just the z? considering in buying one for the dual rear camera which lets you blur the background after taking a pictureI was going to get a Lenovo P2, but settled with a UMI Z, had it 4 days, but happy so far
Good price. But they only seem to have second hand ones at the moment.
The standard g4 is £139 currently, so may get that. The Mrs is wanting a 5.5 inch screen so ruling out the g5.
Going to try and get a lenovo P2.
I gave three a ring and they are hopeful of getting some in my local store tomorrow.
The guy I spoke to said he'd call me when they have stock.
Just wondering, what version of android are these running?
Marshmallow but if you go to the P2 thread there's info on how to install the official Lenovo Nougat update.It's very easy and works very well
The reviews dont rate the G5 very highly, preferring the G4Don't think you'll beat the Moto G5 for a budget android. Lenovo P2 looks nice but it's firmly in a higher price bracket over here.
G5 pros:
Nicer metal build
Better camera AF
Fingerprint scanner
Slightly smaller
Comes with a fast charger
G4 Pros
Uses a marginally quicker but older processor
Have you read the reviews ? I haven't seen 1 recommend the G5 over the G4.
The G5 plus is a different kettle of fish though
The Motorola Moto G5 makes several improvements on its predecessor, mainly in terms of design. The new device is much more premium, whilst also offering a sharper display, more RAM, camera improvements and it adds a fingerprint sensor.
The Moto G4 has a larger battery however, as well as a larger display and there is also the option of a larger internal storage model so some may still prefer this model. The new device costs the same and offers advancements though so it’s the more obvious choice.
If you’ve already got a G4, there’s not really enough here to warrant an upgrade, although the fingerprint scanner and Google Assistant could prove tempting. But for those choosing between the two, it’s an easy one: buy the G5
