Best place to buy Crysis (that actually works)
7 Jan 2009
Hey,
Been wanting to play Crysis (the orignal,not remaster) so i bought it on steam, The bloody thing refuses to start just a black screen then goes back to desktop.
I've tried all sorts of suggestions on the net loads of people have reported the same issues with some saying its caused by the outdated DRM..so now I've put in for a refund on steam as quite frankly its unacceptable they're selling this game in an unplayable state and you have to go around hoops for ages trying to get it to work. And then there's still people who haven't got it to work just as recent as weeks ago.
My question is, Does anyone have Crysis here on another platform (not steam) that it just works?
i cant be doing with hassle and faff. :D
Cheers!
Thanks all, Ill buy it on Origin soon as steam refunds mine, Its around the same price too which is good. :)
Will a game of that age still run on a modern system and current OS?
I don't see why not, It worked on Windows 7 & Vista but i did try the compatibility mode.
If anything it should run better than ever now with more powerful hardware.
Well that was another failure, Doing the exact same thing on Origin..i have now put in for a refund on Origin too.
Guess il skip Crysis then,PC gaming certainly isn't what it use to be :o
PC gamers are not what they used to be by the sounds of it.
You obviously have a problem with an older game which is not exactly unexpected, try troubleshooting it instead of blaming the store you purchased it from.
For what it is worth, the Steam version is not "broken", it is an old game.
You should maybe try Crysis Remastered.
Just fired up the GOG version of this and it's working fine @4K everything Ultra, the only issue I'm seeing is the video sequences seem a bit choppy but the gameplay is fine and it's surprisingly still very pretty even by modern standards.
Have it on both steam and origin. Neither worked out the box, had to fiddle with steam one to get it working on W10. Can't remember what I did, Google helped eventually.
If it doesn't launch as expected on 2 separate platforms, And requires many work arounds to get it working from the get go, That imo IS broken. Agree to disagree on this one.
And no, The remaster is a shambles in fact it looks worse than the original lol.
Cheers Scania :)
Unfortunately you'll find that on loads of older games then.
You have to do stuff like install PhysX, older versions of C redistributables etc.
I played the steam version earlier this year on Win 10 x64. I needed various tweaks to get it working I found from various places cant remember all of them e.g. PCGamingWiki, Steam discussions thread, reddit, gog forums. I wrote them down, hope it helps:
1. Install instructions
- can skip install punkbuster or gamespy since not needed for single player, can just click on cancel when it prompts up
- removed the steam installscript.vdf from game directory (not sure if needed)
- The steam version comes with 32bit version of crysis, can copy 64bit version from crysis warhead (I cant remember what this fixed or if still needed if also using fix in point 2 below to Fix problem with launching the game):
I copied all files from the crysis warhead bin64 folder into the crysis bin32 folder (replace), renamed the Crysis64.exe to Crysis.exe and it worked launching with steam.
2. Fix problem with launching the game
https://steamcommunity.com/app/17300/discussions/0/351660338694333489/
Fixed issue launching game using AMD R5 3600 CPU (6-core), the steam link also has instructions for 8 core CPU:
add to steam game launch options (fix for 6 cores cpu):
C:\Windows\System32\cmd.exe /C start "" /affinity 3E "C:\Program Files (x86)\Steam\steamapps\common\Crysis\Bin32\Crysis.exe" %command%
3. Fix blank screen loading first mission
https://steamcommunity.com/app/17300/discussions/0/1488866180599063784/
Once u come to that black screen press ~ to open dev console
type in con_restricted 0 and hit enter
then type: map island
game should start loading after u do that
4. Fix for refresh rate stuck at 50hz in fullscreen mode
try [alt + enter] few times or play in windowed mode
5. Hold to aim down sight instead of using click toggle
https://steamcommunity.com/app/17300/discussions/0/613938693182120942/
Solution copied from steam link above:
Alright so since this is one of the first results on google, i figured i'd make a quick guide explaining the info above which does in fact allow you to use toggle aim down sight, no need for autohotkey or anything else.
Basically what you need to do is edit an XML file and create a CFG, this isn't too hard even if you don't know what you're doing:
1.) Go into your Crysis save game folder, normally found in C:\Users\[user]\Documents\My Games\Crysis, then go into the 'Profiles' and 'default' folders. In there you should see 3 files, actionmaps, attributes and profile (all .xml)
2.) Open 'actionmaps.xml' in notepad, to this right click on it and select 'open with' or open notepad through the start menu and drag and drop the file onto it
3.) We now need to find 2 lines, to do this in notepad ctrl+f and type 'zoom'. This should take you to the line '<action name="zoom" onPress="1" onRelease="1">'. Underneath this is a line called 'key name' and by default it should be 'mouse2', we need to change this to another key that isn't bound to anything, so i changed mine to 'k', making mine look like this '<key name="k"/>'
4.) Now we need to change the other line, 'xi_zoom'. It should be only a couple lines down from 'zoom', use ctrl+f again if you need to. This line is '<action name="xi_zoom" onPress="1" onRelease="1">' and we need to change this key name to 'mouse2' in the same method used above, so you should end up with '<key name="mouse2"/>' now under the xi_zoom line instead of the normal zoom.
5.) Double check everything, and save the file (File -> Save).
6.) Now we need to make the game realize these changes, and the method to use rather than manually typing thing every time you launch the game is to create a new file. To do this, we now need to find your crysis game install folder. In steam, this will usually be 'C:\Program Files (x86)\Steam\steamapps\common\Crysis', if you've changed the install location you know how to find this anyway.
7.) Now that we're in the crysis game folder, go into 'Game' then 'Config', you should end up at 'steamapps\common\Crysis\Game\Config'. This is where we need to place the new file we're going to create.
8.) Open notepad again, and paste these 2 lines into a new blank note 'con_restricted=0' and 'hud_ctrlzoommode=1'. Don't include the ' and make sure they're on 2 different lines. We now need to save this as a config file, to do this go 'File -> Save As' and as the name put 'autoexec.cfg' and change the file type from '.txt' to 'all files'. Save it on the desktop to make life easy.
9.) Now we copy and paste 'autoexec.cfg' into the 'Crysis\Game\Config' folder, which should end up with autoexec at the top of a bunch of other .cfg files.
10.) We should be done now, load up crysis and press the tilde key '~' (above tab, next to 1). If you've done it correctly, it should have both of the 'con_restricted=0' and 'hud_ctrlzoommode=1' lines in green. Now just load up a save and you should have aim down sights as a toggle on your right mouse button.
I just quickly booted up my original crysis version on steam on windows 10 ;)
Hey,
Cheers!
Looks like it maybe not working due to you having an AMD CPU
Crysis fix - how to play with AMD (especially Ryzen), DRM fix :: Crysis General Discussions (steamcommunity.com)
Guys one thing I will say and it's not just crysis.
Check Windows folder access, see if it's denying access to the game your trying to use.
I had an issue booting up the game after getting this 5800X - worked by replacing the dll with this one from here - https://community.pcgamingwiki.com/files/file/1411-crysis-amds-3d-now-fix/
My old 5820K bottlenecked the 1080ti in crysis 1 due to the single thread reliance, can get actual decent fps on the new ryzen :p
