- 22 Sep 2020
hi what are the best large sata HDD's not SSD looking for 8TB or 10TB drive i was looking at WD Black drive
I love the sound of old 5.25" hard drives, in particular the Miniscribe brand.5400 is a lot quieter than 7200. You should hear the old 3.5inch wd raptors lol or better yet 3.5inch sas 15k... Music to my ears![]()
At one time Maxtors were also quite good at making seek noises.5400 is a lot quieter than 7200. You should hear the old 3.5inch wd raptors lol or better yet 3.5inch sas 15k... Music to my ears![]()
This is 7200 RPM, there are no high capacity 5400 RPM drives. Western Digital only reports the RPM as 5400 because it is a '5400 RPM class' drive with firmware artificially slowing down the speed, but the actual rotation rate is 7200 RPM. Many people have verified it with acoustic analysis, and you can actually bypass the firmware speed lock for a while by running a short SMART self test.Have a shucked WD 14TB wd140edfz in my system.
5200rpm so its relatively quiet.
maybeThis is 7200 RPM, there are no high capacity 5400 RPM drives. Western Digital only reports the RPM as 5400 because it is a '5400 RPM class' drive with firmware artificially slowing down the speed, but the actual rotation rate is 7200 RPM. Many people have verified it with acoustic analysis, and you can actually bypass the firmware speed lock for a while by running a short SMART self test.
I have the same 14TB drive and it is quiet, but it is definitely 7200 RPM. If I do a SMART short test during a disk scan speeds will jump from 225 MB/s to 280 MB/s.maybe
I can confirm it is slower than my other large drives. And also quieter, from less aggressive read head movements then?
what are the dif in performance in them 2? i'm not looking for a 100% silent just most quietest drive out of 7,200rpm drive i have 2 old segate pros 6TB drive at mo that not too badHonestly I'd say you're going to struggle to find any really quiet drive these days... although some in the past did have the ability to change settings in the firmware but no idea if that's still a thing.
As above WD black is not a quiet drive, same would apply for enterprise class drives (seagate exos, WD gold etc)
Are you ok with SMR (aka shingled) or do you need CMR drives because it all makes a difference. Most consumer drives are SMR, nas focused drives can go both ways and enterprise is generally CMR.
SMR - in a home computer with just one drive you likely wouldn't notice much difference over a CMR drive, put it in a raid array or similar and SMR will cause no end of issues.what are the dif in performance in them 2? i'm not looking for a 100% silent just most quietest drive out of 7,200rpm drive i have 2 old segate pros 6TB drive at mo that not too bad
Oh man had a original 36gb and 150gb Raptor with the window, good ol days. In my quest for peace and speed i had 15k scsi arrays in Raid 0...dark days compared to ssds...the noise and vibration! if only large capacity ssds were as cheap as predicted by now.5400 is a lot quieter than 7200. You should hear the old 3.5inch wd raptors lol or better yet 3.5inch sas 15k... Music to my ears![]()
