I was thinking of these OCZ Platinum 4GB (2x2GB) DDR3 PC3-10666C7 1333MHz Dual Channe
or these
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
I have my mobo and cpu already just need the ram then i can connect and away i go.
What do you recommend? If you know of any better please say. Must be under £70 and 3gig minimum...
thanks
i found these Patriot Viper 3GB (3x1GB) DDR3 PC3-12800 (1600MHz) Low Latency Tri-Channel Do you think the will work on a P55 mobo?
or these
thanks
