- 13 Feb 2020
Hello,
I am currently deciding between going AMD or Intel for my next system and I am putting together a list of parts for both possible systems. If I went Intel I would probably go for an i9-9900K and an Aorus Master, as these have both been recommended, but I have no clue what RAM to get. I have seen the Patriot Viper Steel 4400Mhz get good reviews; it has low CAS timings of 19-19-19-39 and is pretty cheap at £128.99 when compared to other similar RAM kits - the next-cheapest here is £248.99. Would the Patriot Viper Steel 4400Mhz kit be compatible with my i9-9900K and Aorus Master though? I've checked the QVL for the Aorus Master and the Viper kit isn't listed. I know the QVL list isn't exhaustive, so is there still a good chance it would work? As you can probably tell I'm quite noobish about these things.
Thanks.
Thanks.
