You just need a router or router and modem?
What's your budget?
and by best do you mean for WIFI or?
The problem with Asus and Routers are that they are slow to update firmware and they can also be bit sloppy when they do leaving broken code. When they do get is wright they are some of best Routers going so never buy the latest model always give it 12 to 18 months.
One word - Merlin!![]()
I'd probably give the new Netgear D6400 a try.
Can't recommend the ASUS DSL-AC68U as it's unstable on mine and many others connections.
I have a Draytek 2860n on plusnet fiber, very stable router.
I have had some bad results with DrayTek in the past (more due to them listing specs and them failing to live up to them).
However the 2860 does seem to have a good rep and with the latest firmware it is supposed to work well with G.INP etc now, need to use v2860_3782_vector2.zip I believe.
Would be interesting to see what the 2860ac is like.
