Best Sandforce SSD 120GB Drive Performance
18 Aug 2011
Which SSD out of OCZ Vertex 3 Max IOPS 120gb, Kingston HyperX SSD 120gb and Corsair Force GT 120gb would perform the best in FX990 chipset setup. They cost £220, £200, £180 so I am not that worried about price too much. I just cant find any reviews for all of them where they are 120gb...
Look up reviews I guess. I thought the Corsair was the fastest drive, but the Kingston looks new to the market and the advertised stats look good.
For support and quality, either of these. I'm always more wary of OCZ.
Max iops has toggle NAND (best quality), the other two are synchronous (second best). Other toggle drives are the Mushkin Chronos Deluxe and the Patriot Wildfire. Synchronous and toggle are supposed to lose less performance when filled up than asynchronous drives and cope better with incompressible data. Meanwhile, toggle drives hold similar performance at a given capacity as the synchronous drive holds at the capacity above, ie. the max iops 120gb is similar in performance to the vertex 3 240gb.
So, of those three drives, money being no object, get the max iops. If you are willing to look around a bit, look into the other two toggle drives. That said, all three seem to be largely the same (as all sand force drives of each memory type seem to be).
