Best SFTP client?
1 Nov 2007
England
I'm pretty sure I'm going to get Transmit but before I do I wanted to check if there was anything out there that I didn't know about. I've looked at Cyberduck which also looks good but I think I still prefer the look of Transmit.
Then again there is Filezilla which is free and looks reasonable. Which client would you use?
I bought CyberDuck a while ago when I had problems with an old version of Transmit. I do prefer Transmit though but it's just so expensive.
I don't like FileZilla, I've never liked the interface, it's never seemed intuitive to me.
I just use the terminal, or more specifically iTerm2 as that's my terminal of choice. I use SCP more than any man should in the modern day and age at work, and I just find it much easier than a cumbersome GUI to use the keyboard on the terminal.
CLI or FileZilla for SFTP. Cyberduck (with nag screen) for other protocols although i've yet to find a reason to justify spending $40/50 on Transmit.
Yeah the price is an issue but it is also a really useful tool so I'm prepared to spend the money if it is worth it.
Transmit for me.
I just wish it would do SMB connections, then it would be perfect.
Thanks. SMB would be a nice addition.
I would do on terminal but I'm not sure how to write a script for my use case.
Basically I need to write some software on Linux x86_64 which I can't do on my Mac because it is Apple Silicon. I could emulate x86_64 using QEMU but the speed is awful.
That leaves me two options. I can write my software on my Mac and upload it using SCP or SFTP or I could create an NFS network share on the Linux server and just treat it like a normal local directory by mounting it on my Mac. The only reason I'm not sure about this is because of security. I haven't used NFS in a proper way at all so I'm not sure what the pros and cons are.
Thank you.
